Geht das beim Jimny Bj 2010
DRL Function Setting Procedure
DRL is controlled by BCM which has a function to set
operable / non-operable mode of DRL. With a new BCM,
its DRL is set to the non-operable mode.
Therefore, when BCM has been replaced in the country
where DRL operation is required by the statutory
regulation, set DRL to the operable mode according to
the procedure described below.
Also, performing the same procedure when DRL is in the
operable mode will change DRL setting to the nonoperable
mode.
1) Turn ignition switch to ON position.
2) Perform Steps a) through f) described blow within 15
seconds after Step 1).
a) Turn lighting switch to CLEARANCE position.
b) Turn lighting switch to OFF position.
c) Repeat Steps a) and b) five times.
d) Turn lighting switch to HEAD position.
e) Turn lighting switch to OFF position.
f) Repeat Steps a) and e) five times.
3) After Step f), buzzer sounds twice which indicates
that DRL has been set to operable mode.
NOTE
When DRL setting has been changed from
operable mode to non-operable mode, buzzer
sounds once.
4) After confirming buzzer, turn ignition switch to OFF
position.
