Reifen......Reifen....Reifen
  • What Fits? Tyre Chart
    Tyre Size Suspension Spec Rim Size Body Lift Flares
    205/70-R15
    (26") Stock (OE) Original Equipment Standard
    15 x 5.5" Not Required No Cutting Required
    215/75-R15
    (28") No lift required for street use. 2" (50mm) lift recommended for trail use. Standard
    15 x 5.5" Not Required No Cutting Required, but some rubbing can occur when front wheels are turned.
    225/75-R15
    (29") 2" (50mm) lift recommended. Standard
    15 x 5.5"
    15 x 6" or higher width recommended Not Required but 1" body lift would do great things for articulation. A bit of inside flare shaving recommended.
    235/75-R15
    30x9.5
    (30") 2" (50mm) lift for street use 3-4" lift recommended. Brake line extensions needed. 15 x 6"
    15 x 7" recommended Minimum 1" body lift is recommended with 3" springs. Some East - West cutting of the flares recommended.
    31 x 10.5
    (31") 4" lift required
    5"+ require longer drop arms. 15 x 7" recommended Minimum 1" body lift is recommended with 4" springs. Some East - West cutting of the flares recommended.
    32 x 11.5
    (32") 4" lift required
    15 x 8" Minimum 2 - 3" body lift is recommended with 4" springs. Some East - West cutting of the flares recommended.
    Disclaimer | Copyright JimnyWorld.com © 2004
    liebe Grüße von Harry
    Das war mal meiner................
